daverz
May 22, 2016Explorer
Yes, all 4 should come down and contact the ground. Sounds like your sensor got confused. Did you have people moving around in the coach while it was trying to level itself? If so, that might be the problem.
I'd recommend retracting the levelers (use "emergency" retract if needed), until all 4 are up. Turn the system off/on, then try again.
As a general rule, I always make everyone get out during leveling time, or at least everyone must be seated and not moving.
Bigfoot has good tech support if you need to call them. Very nice and helpful.
Good luck
Dave
Good luck
Dave
38,763 PostsLatest Activity: Dec 05, 2025
