roadrat57's avatar
roadrat57
Black and grey tank sensors
My newly purchased 2008 Fleetwood 31lx shows both black and grey at one third full. The tanks are empty. Did some research and found I can possibly clean the sensors a variety of ways.
Make some sense the lowest sensor for each tank is experiencing a bad read.
Any suggestions, as usual, would be greatly appreciated. I have used this forum frequently and I have very much appreciated all the responses.
Thanks!
  • Sounds like the previous owner(s) didn't take very good care of their black tank. Yes, sensors can be troublesome but also can be fairly accurate if the tank is subjected to a procedure that will prohibit build up on the sensors.
    I have found the best way to accomplish this is to empty the tank and flush out prior to traveling. I put about 5 gallons of water in the tank along with a cup of liquid laundry detergent (I use Oxy-Clean) and a 1/2 cup of Calgon water softener. While traveling to my next destination, the solution will slosh around in the tank "loosening" any residue left in there. Upon arrival at my destination, I'll drain the tank once more and put another 5 gallons back into prior to using the toilet.
    This procedure has worked for me will all my rv's from our first single axle trailer to our 44' motor home and I highly recommend it.
    In the OPs case, this procedure might take two or three trips to eventually get everything off of the season.....but it will work.:C
    Hope this helps
    Ron
  • I always figure how long we can go based on experience. However, my gauges work very well and seldom plug up. I never use the backflush system except at the end of year and I'm going to winterize.
    The only treatment we use, never have had any smell, is from Unique - DigestIt. A natural treatment and it will dissolve all items keeping the system flowing well.
    OK now that I've said this it must be time for me to be attacked. Go for it.
  • DrewE's avatar
    DrewE
    Explorer III
    For me, rinsing out the tanks (using a spray wand for the black tank) and letting them sit makes the sensors work properly. Putting some cleaner like dishwasher detergent in the water and letting it sit and slosh around would probably also do a nice job...or you can look up the "GEO method" for tank cleaning here for a rather more complicated but apparently quite effective tank cleaning regimen.
    There are a number of people who say the sensors never work reliably and hence are useless. I find mine actually work fairly well most of the time and I do find them handy, though not essential. I wonder if the people who say they're useless say that because they've never had ones that work consistently; it strikes me as perhaps the attitude of someone who has a broken gas gauge and says that the gas gauge is not very accurate and you can always figure when to gas up based on mileage since the last fill-up. Those are both true statements, but it doesn't mean that a gas gauge, or a holding tank gauge, is not also handy.
  • 2oldman wrote:
    The common response to this is: forget about those sensors. They rarely work properly.
    You can obsess over cleaning them only to have them gunk up next time tanks are used.
    Tank level sensors like battery level monitor are just 'do-dads' for salesmen to point out. Oo-Ahh.
    Toilet 'burps'----time to dump black tank
    Sink/shower draining slower....time to dump grey tank
    Water pump goes 'brrruup'....need more fresh water
    After a few trips you will get a handle on how long before each each tank fills up.
    Dump when full
  • Black tank, shine a flash light down the hole...my gray tank sensors reading are petty close.
  • I use the sensor lights to let me know how clean my tanks are. If I am hooked with my drain hose, I will fill and rinse my tanks - normally about 3 times, and when all the sensor lights read empty, I feel the tanks are clean "enough".
    If your sensors have a film of **** that has been dry for a long time, it may take more than a few rinses.
    Ice cubes, water, and driving around may help some on getting the senors cleaner.
  • The common response to this is: forget about those sensors. They rarely work properly.
