Look for a vacuum breaker under your sink which connects to the black tank flush system. Here's a link to a kit which has a brass vacuum break.
Black Tank Flush Kit with Vacuum BreakerThe brass unit is the vacuum break. This is similar to the one in our rig, but ours is under the kitchen sink. The disk part of the breaker should point upward with the two pipes coming up from the floor.
It is only connected to the black tank flush plumbing, so if you're not flushing your tank, it won't show evidence of a leak.
The vacuum break line has to be higher than the rest of the plumbing for the flush system to help prevent siphoning, along with the vacuum breaker, which is why they're mounted inside and usually under a sink cabinet.
Hope this helps.
~Rick
