IAMICHABOD wrote:
But I got tired of dragging the hose in and all the mess that it made
It looks like this when finished, with a quick disconnect on the end.
Don't get discouraged if it leaks at the hose connections at first they are sometimes hard to get tight. Tightened mine up and have had no leaks anywhere.
Another suggestion is to make a test hole in a piece of wood or something and test fit the device to the hole. I found that the hole size suggested was much larger than needed.
Good Luck.
BTW Welcome to the Former Rental Club
I installed the same rinsing system on our B+, works great.
