DutchmenSport
Aug 09, 2016Explorer
rockhillmanor wrote:
When you dump if you fill it back up with water and dump again each every time you dump the sensors WILL work all the time. The second fill up of plain water cleans out any paper/poop stuck to the sensors.
It's what I do and My sensors work all the time.:C
The only problem with this is, if you dump at the dump station because you do not have full hook-ups, you're going to have multiple RV.net forum members behind you complaining you are taking too long at the dump station. To fill the tank a second time and then dump it again, well, you've just added another 20 minutes or more to your stop at the dump station. (I'm just saying???) Full hook-up sites, yes you can spend the time to refill the holding tank, no problem. But at dump stations, you don't have the luxury of this much time.
If you are on a seasonal site, filling the tank a second time is about the only way to clean the sensors, unless you have a toilet wand or a black-tank flusher installed.
38,769 PostsLatest Activity: Apr 04, 2026
