luggnutts wrote:
I have a problem with my black water guage. So I'm here for the help i know I'll get . My guage reads 2/3rds full even though the tank is empty. This has been confirmed by others (rv owners) who say they have had the same problem. Done the suggested remedies IE; 5 lbs ice 10lbs ice 20lbs ice down toilet, then drive around to agitate the ice in the tank and clean the sensor.Having done the ice thing with no luck. I tried a tank scrubber that was loaned to me by a fellow rver. tried this method twice, with no luck. I can't be the only one with this problem !!. OH I've also been told to replace one or both units ( sending unit or or the panel unit). THANkS IN ADVANCE, FOR THE HELP I KNOW IS COMING.
First, forget the worthless gauge with it's always dirty sensors, with no matter what you might do, to permanently correct it.
Second, use a lot of water for flushing, dump every 3 - 4 days and save yourself not only the use of chemicals, but combating unwanted smells from time to time.
We only use chemicals for storing and have less problems than most.
