ScottG
Jul 26, 2017Nomad
htowners wrote:
Most likely a low voltage situation occurred which caused a spike in amperage draw. This is a guess, otherwise a lose connection causing a similar situation. Wire is rated for amperage and too high causes resistance which converts to heat.
It's hard to guess on where the wire originates, it'll just be a matter of getting behind the water heater and tracing it.
Good luck, hopefully other Monaco owners might have a better idea of tracing the wire.
I think your on the right track but low voltage will not cause an increase in current for a heating element. Lower voltage through a resistive load results in less current.
Chances are, the connection just became loose and was not able to carry the current load anymore.
38,774 PostsLatest Activity: Apr 26, 2026
