dicknellen
Aug 08, 2013Explorer II
You have the True Level tank indicators that Winnebago started using in 2005, I have the same problem with our True Level black tank indicator. The gray and fresh water, battery condition & propane are all working as they should. My black tank indicator worked up until 4 months ago then just started showing empty. Since it is the black tank I can shine a flashlight directly into the tank by opening the toilet flush lever to see how full it is. I got underneath my Winnie and found all the tank contacts on the black tank and they all looked ok. I will be watching post on this forum to see if you get a answer. Regards, Dick
38,778 PostsLatest Activity: Jun 06, 2026
