Rolin
Aug 09, 2013Explorer
Dicknellen, you are right, I do have the true level tank level indicators. Trying to trace the lines but the lines from the monitor panel go to a junction and ALL of the lines from the junction are yellow, can't find a way to differentiate which is which. Winnebago uses a LOT of yellow wire. Must be 500lbs of wire running around on the motorhome.
Tried to find the connectors on the black and grey tanks but because they are enclosed on the Aspect 26A motorhome it wasn't possible to see much. I am learning more about how this thing is put together. May have to go underneath and see if the panel on the bottom is removable. Or better said, if it is removable by me.
The empty light is always on, if the indicators are working then as the tank fills the 1/3, 2/3, full lights will also turn on. Found that the true level indicators are wired in series. 1/3 tied to 2/3, tied to Full. Downloading a wiring diagram from Winnebago and will see what I can learn from that.
38,778 PostsLatest Activity: Jun 06, 2026
