et2
Aug 01, 2014Explorer
Executive wrote:pappaone wrote:Skip n' Stones wrote:
Looking in the toilet above the tanks is full. Pull the handle below and no draining...kinda of a drip then nothing. Pulled the panel and the rod handle is attached to the upper valve. Cannot tell if it is disconnected rod or clogged exit drain in tank.
Any suggestions soon as we are on the road.
Skip n' Stones we had the same problem a couple of years back, it turned out to be a T paper clog before the valve, not a fun thing to take care of. If you need futher info PM me and I will explain what we did. Good Luck
Rich
Why not 'splain it HERE...:h:h.....posting a SOLUTION in a PM helps only the OP.....:S.......just sayin.....Dennis
Just guessing, Using this and back flush through the open tank valve after connecting it to a water source. Then open the flush valve and let her go.
http://www.amazon.com/s/?ie=UTF8&keywords=king+flush&tag=googhydr-20&index=aps&hvadid=31656888157&hvpos=1t1&hvexid=&hvnetw=g&hvrand=17968551678121470737&hvpone=&hvptwo=&hvqmt=e&hvdev=t&ref=pd_sl_9e4zdoj6tx_e
38,766 PostsLatest Activity: Jan 10, 2026
