RayChez
May 27, 2014Explorer
Hedgehog wrote:
If the price was within fifty dollars per tire out the door, would you prefer the balancing to be done with equal or with weights attached to the rims? I have found to recommended shops and each has there own method. The shop that uses equal only does so because they don't have the weights for aluminum wheels
The only way you will find out which is better is for you to try Equal vs lead weights. Either Equal is very good or the rims and chassis on my coach is designed for the perfectly smooth ride. I say Equal is the best because I have had experience using it on two sets of tires and the tread on the tires the day I had them changed looked like the day I bought the tires new. Even wear across the tread of the tire. No cupping, river ring etc etc. So I really do not care what other people use, that is their prerogative. But I will always use Equal the powder on balancing my wheels on my coach and install X-Air valve stems (filtered).
38,780 PostsLatest Activity: Aug 05, 2026
