I just picked up a 2008 MH with the True Center installed but it doesn't seem to work (there is a rocker switch just beside the exhaust brake switch). My steering wheel has to be constantly held to the right (getting an alignment done soon).
I looked in the manual and it says you can burn out the device if the switch is held for 30 seconds or more. Maybe the PO did this?
Anyone know how to check to see if something is burnt out? Where should I check for power?
On second thought maybe I should try to see if really is hooked up?? Trace the wires if I can?
thanks
Chris
