korbe
Jun 02, 2017Explorer
DutchmenSport wrote:
.........2) If you are parked on asphalt. The weight of the camper and not moving the camper at all in heat, can cause the asphalt under the tires to soften and result in the asphalt having dimples where the tires sat. If you use boards, the weight of the camper is distributed over a wider area and will not cause the asphalt to dimple........
I have seen board depressions in soft AC pavement too. However, my conclusion is that the AC mix design used the wrong oil type or percentage.
