So we took our first mini-trip this past weekend on the coach and had an absolute BLAST!! Everything worked great and we couldn't have enjoyed ourselves more unless someone else paid for everything! ...
All of the above should be checked. Shocks are probably worn, sway bar bushings could be worn, tire pressure could be wrong if coach was not weighed as per the load, and the springs could have sagged to the point that your ride height is too low. Not a bad idea to go over everything with the suspension to insure that all is in good shape. It doesn't sound like you have any major problems and it may be just a few minor things need attention.
