So we took our first mini-trip this past weekend on the coach and had an absolute BLAST!! Everything worked great and we couldn't have enjoyed ourselves more unless someone else paid for everything! ...
Again, thanks for the info! I'll take a look at the coach and will probably do that simple mod.
Question for you, C-Leigh Racing,.... is there significant load on the sway bar as it sits parked in the driveway that needs unloading before removing the bolt on the link to move to the inner mounting hole? If so, how did you unload the tension on the sway bar? Is simply jacking the coach up on the levelers enough?
