Got my rear bushings replaced last night...the OEMs were completely gone...melted away and what remained was gummy. I ran out of daylight before I could replace the front bushings, but they actually "LOOKED" okay. I'll probably go ahead and replace them anyway since I have the new poly bushings for the front too.
I tried to get the sway bar in place for the McKinley Fix, but apparently I'm geometrically challenged, since I couldn't make the end links fit into the second set of holes without risking hitting the differential housing with the sway bar when the rear axle moves. I'll ride around on the coach with just the new bushings and see if that corrects my body roll/sway problem before making further modifications. Otherwise, I guess I'll have to purchase longer end links to make the switch.
To be continued.........
