Brodie3Az
Sep 02, 2013Explorer
It sounds like the load on the rear springs may possibly contribute to your situation, the rear end setting closer to the road surface than desired.
Changing to larger diameter rollers will only increase the frequency of your bottoming out.
You may want to look at installing an Add-a-Leaf which might produce a stiffer ride or installing air bags at the rear axle.
