RnRs-RT
Jul 21, 2015Explorer
Not encouraging a fix but a weld done by a good welder should not brake. The metal will probably brake before the weld. That being said, I have seen some draw bar and receivers in some of the discount stores that look like some kindergartner did the weld job. Anyone can make a bubble gum weld but a good welder will make a good penetrating weld that should be as strong as or stronger than the base metal.
I can weld but do not consider myself a professional welder but I worked in construction around steam fitter welders and I would defiantly trust their work.
38,769 PostsLatest Activity: Apr 03, 2026
