donn0128
Mar 13, 2015Explorer II
You have or at least when new it had a CONverter. This device among other things charges the house battery. I suspect the converter is dead. To check it, plug the RV into shore power, disconnect the two battery cables from the battery and measure the voltage across them. From the converter you should read around 13.6VDC.
