Jerry__and_Kare's avatar
Dec 09, 2013
Bounder 39Z
All the labels were removed from my incoming wires leading to my switch panel & VCR & the antenna booster. Guess my first mistake was letting a Mediacom technician into my motorhome! Now the booster boxes for that service have been removed, and I am struggling to get my antenna and VCR reconnected. Any suggestions?
  • You may have to do a continuity check from the antenna by running a cable out the window to the roof antenna lead in. The VCR a continuity check on the cable from the VCR up to the booster to which ever cable has continuity is the one to the booster.
  • If it's the matter of running the cable, get a tool called a "fish tape" from Harbor Freight or Home Depot. It should help you run the cable between the wall and whatever else you need to run it through.
