Horsedoc
Mar 08, 2014Explorer II
I just worry about pulleys and cables and screws in the firewall. Screws can pop out on a lot of pressure, cables can kink and the brake pedal not retreat. If I was going with that kind of system, I might use the Air Force One since it does not have to rely on brute pressure on the brake pedal. It keeps vacuum pressure up on the towed. We use the regular ole Brake Buddy (proportional braking) and it has worked fine thus far. It is a PIA when you arrive and have to find a place to set it when you use the towed
38,774 PostsLatest Activity: Apr 26, 2026
