tropical36
Mar 08, 2014Explorer
Horsedoc wrote:
I just worry about pulleys and cables and screws in the firewall. Screws can pop out on a lot of pressure, cables can kink and the brake pedal not retreat. If I was going with that kind of system, I might use the Air Force One since it does not have to rely on brute pressure on the brake pedal. It keeps vacuum pressure up on the towed. We use the regular ole Brake Buddy (proportional braking) and it has worked fine thus far. It is a PIA when you arrive and have to find a place to set it when you use the towed
Sounds like the way that the Stealth is engineered, but not so with READYBRAKE and not much there to go wrong unless a cub bear with boxing gloves on, installed it and even with Momma and Poppa bear pulling on it. Even then, there couldn't be much to fix and again, there's the initial cost of these high tech systems to consider and not much use in paying more to get less in the long run.
38,774 PostsLatest Activity: Apr 26, 2026
