dangerbird
Aug 13, 2017Explorer
If the braking system was at fault, wouldn't the rear brakes be affected too? The OP stated the brakes were just done. A couple things to think about... Were the calipers taken apart and the slides lubed? Are the piston(s) clean so that they can retract properly? Were the calipers hung properly when removed?... not by the hoses. A well bled system will retract better than one with air in the lines.
Carl
Carl
38,771 PostsLatest Activity: Apr 14, 2026
