WyoTraveler wrote:
Not familar why you need to need to disconnect your battery. Or even why several toads recommend it. Is it because it will discharge the battery? Or other reason? I use the Blue Ox Patriot. It does have a small battery. I also run a charge line through a diode to charge my toad battery while towing. You need to isolate the charge line with a diode. My toad is a Jeep. If you have a charge line not sure why you would need to diconnect your ground.
??? that's what the OP is asking here. can he run a charge line instead of disconnecting the batt cable and of course the answer is most certainly
