joe_b_
May 26, 2013Explorer II
As J-D says, drum brakes are labor intensive to examine. First the tire(s) need to be removed, then the drum pulled to be able to check the condition of the brake shoes and wear on the drums. Then, if all is OK, new seals will be needed and then the drum replaced, the brakes readjusted, if needed and the tires remounted. A good mechanic with good equipment is going to be somewhere around an hour and a half of labor by the time they finish the rear brakes on both sides. You might as well replace the brake shoes while in there, as the parts are a minor part of the cost. Disc brakes should only take 5 minutes and a flash light to check. A simple task that most RV owners can learn to do.
38,783 PostsLatest Activity: Sep 23, 2026
