joe_b_
May 27, 2013Explorer II
Squeaks can be from brake dust build up, from the built in wear indicators letting you know you need to replace them but I have found squeaks that come and go tends to be from a vibrating disk. To cure this issue, you need to remove the disk brake pad and spray the metal back side with an anti squeak product suck as made by Permatex. I thought the guy that first told me about this was pulling my leg but it worked. Make sure you only get the spray on the back side of the pad, and not on the surface that rides against the rotor.
38,783 PostsLatest Activity: Sep 24, 2026
