wolfe10
May 27, 2013Explorer
hrgermany wrote:
It is important to check the brakes,but also imported is to change the
brake fluid every few years.The brake fluid picks up moisture that lowers the boiling point.I had to learn that the hard way,when my brakes
failed.Brake fluid is not costly and the fluid is easy to change.
Hans Rueckert
1995 BF 26FT RSB
Very important. Whether you wear out brakes in 10,000 miles or 100,000 miles depends on where you drive and your driving style.
BUT, brake fluid absorbs moisture (to protect the iron brake parts). When it does so, the boiling point of the brake fluid goes from around 500 degrees F (new) down to around 286 degrees F. On hard braking, the temperatures in your calipers can exceed the 286 figure and you loose braking!
38,783 PostsLatest Activity: Sep 23, 2026
