willie220
Jun 08, 2013Explorer
Brake Woes/ recall fix on Work Horse 22P
I took my 2004 Bounder in for its annual chassis maintenance: oil change, lube, generator service and chassis check. Then I got a call that made me just sick. I was informed that both of my front brake calipers were seized up. The right one so tight it had completely worn the pad down and had scored the rotor beyond repair and the heat buildup had even cracked the rotor. The left side still had some pad left but, the heat buildup had cracked the rotor on that side also. All of this had happened in just a few thousand miles. I hadn't noticed any pulling since the calipers were seizing on both sides. I hadn't any indicators that there was a problem with the brakes at all when we had it out. The sensors haven't been checked yet to see if they were or are working. We had the recall "fix" done in November 2010. Took the coach out for a cross-country trip for 5 months in 2011 putting about 10,000 miles on it. Everything checked out ok when it was serviced in fall 2011. Took it out for only 8 weeks last year, 2012 putting a little over 2,000 miles on it. I do take it out for a drive every month to keep all of the fluids and everything moving. Now I am looking at a major expense in getting fixed what I feel the recall fix failed to do. Anyone else out there have a problem since their Work Horse brake recall fix????:(
