Bill.Satellite wrote:
Is your RV a semi or an RV. If it's a semi I would suggest that you run and run very fast. If it is an RV and it happens to have air brakes then my original post remains......Push the brake pedal and the RV stops. You really don't need to know anything else.
The air system on an rv is the same as a semi.
There are things that you should know such as they require periodic adjustment unlike hydraulic brakes among other things.
It isn't Rocket Science but knowing a little more then just pushing the peddle will probably be more like the advice you are looking for.
