Stim
Sep 10, 2018Explorer
The P chassis have had a problem with front brake hoses.
The hose will fail internally and act as a check valve and not release pressure.
I had that problem with a 1983 Winnie and a 1989 Southwind class A's.
If you can look at the calipers you should see that rusted/overheated look.
Also if you go to buy the new hoses you need to take the old hoses to match them up. The hose/frame bracket is different on some units.
38,774 PostsLatest Activity: Apr 26, 2026
