Jun 16, 2015Explorer
Dutch_12078 wrote:lovervn2 wrote:
I have the ready brake system with my Class A Sightseer 34' and Toyota 4Runner automatic with drive shaft disconnect. I am having one heck of a hard time getting it to work properly. It appears the brakes on the Toyota are not releasing. I have talked to the mfg. and they haven't been a lot of help. Said I needed the anti rattlers cuz there was too much play. That didn't work at all. I'm about ready to thro it in the ocean it has been such a hassle! Do you have any suggestions? The only thing that I wonder about is the break cable is not going down the middle thr the release lever on the top of to bar. Any help greatly appreciated!
Can you post some photos so we can see how you have it set up? The hook up cable should be running from the ReadyBrake actuating lever to the toad cable eye at the center of the toad grill in a straight line. When hooked up there should be just a small amount of slack in the cable.
X2
The only time my Ready Brake doesn't release is if I stop facing down hill. That will keep the brake lights on and kill the toad's battery. Other than that, it works great.
