JamesE117's avatar
JamesE117
Bravura Low Parch Won't Flush
My DOD 31119, Bravura, Low Parch, won't flush. Worked just fine a few days ago and now when you step on the front foot pedal water will come in and swirl around but no flush. Any suggestions?
Thanks,
Jim
  • Did you push the pedal all the way down after the water is flowing? If so see if something is under pedal blocking it from going down?
  • Thanks, I will look. I had it off and saw a rod on the left that looked like it went from the mechanism operated by the foot pedal to some connection in the center of the rear of the unit and it was all connected because I tried pulling on that rod, but I will look more carefully. Thanks for taking the time to help.
    Jim
