Nui's avatar
Nui
Broke charger on Brake Buddy
I smashed the lighter adaptor on my brake buddy when I slammed the door on it. The fuse inside broke and the black plastic housing piece broke off at the end of the charger.
I put in a 20 amp fuse and glued/taped the plastic back together. The silver knobby thing at the end still goes in and out.
Should I even attempt to plug this in or am I going to blow up my brake buddy?
Naturally, I'm heading into the mountains tomorrow.
Any advice on repairs?
Nui
  • One thing to note there are two sizes of those plugs out there. One is slightly larger and is a very tight fit in the receptacle. Make sure you get one with the right diameter.
  • Don't SLAM doors.....:B:B.....Dennis
    If you feel you need it until you get the proper repair from BB, follow the previous advice. Temp fix from auto parts store. I would make my perm fix with parts directly from BB.....Dennis
  • Auto Zone, Advance, NAPA, Car Quest, etc. will have parts to repair it. Get wire Gage same or heavier.
  • For the ease of getting it fixed right away and back on the road, go to AutoZone and pick up a new plug and wire it onto the Brake Buddy. If your unsure of how to do it, take the Brake Buddy into the Autozone and I'll bet you a dollar to a Krispy Kreme Doughnut, they will do it for you.
  • I did a similar thing. I bought a replacement that never worked right. It would pop the fuse in the truck. I then called Brake Buddy and they sold me a new one. I installed it and now everything is cool.
  • You can buy replacements at Radio Shack. Buy the heaviest duty one you can, and pay attention to polarity.
  • Had a similar problem, I emailed BB and they sent me a new plug, cord, etc, with instructions to install properly.
    Oh, they didn't even charge me for the replacement. Great Customer Service.
    I would not use a plug that was damaged. To easy to and cheap to replace, compared to the cost to repair/replace the BB unit.
    That's just me. Don't want to get hit by lightning.
