skipro3 wrote:
Sounds like your brake caliper picked up a rock. I've had exact same symptoms and it was just a rock. If it were me, I'd jack up and remove the tire, then spin the rotor and look, listen, feel for where the noise is coming from. might see a mark on the rotor where the rock is rubbing.
It could also be a broken brake pad that came loose and rubbing loose in there.
I do not suspect wheel bearing though. No wobble, no heating up, etc. A wheel bearing will generate a lot of heat usually.
I am going to go ditto on this also as the first thing to eliminate or fix.
JimR
