Jacks will not go down and bedroom silde went out 6" and stopped. now it will not retract no sound of motor. Passager side slide how con I get ti back in so I can move? If I can manualy retract it OK ...
If you cannot solve the power problem, you will need to take the mattress off the bed, and remove the top of the bed platform to access the motor and drive mechanism. As others have said, check your 12V power path to the slide for continuity. It could even be a bad connector.
