Johno02
Dec 06, 2015Explorer
duffert, do look to see if you have a facing around the door frame! if so, it is a lot easier to remove the facing, which will expose the striker plate and latch bolt. Then just push it with a screwdriver, and the door is open. You are going to have to replace the striker plate anyway. You are right, there is no way to get a blade or anything between the door and the frame, which is NOT what I am telling you. The facing is part of the wall next to the door, and concels the gap between the door FRAME and the wall.
38,782 PostsLatest Activity: Sep 10, 2026
