TucsonJim
Jul 26, 2015Explorer II
It sounds like you have a defective converter (not inverter) that is providing much more than the required DC voltage to charge your battery and run your light bulbs. If you have a volt meter, check the voltage at the battery terminals with everything plugged in and turned on. If the voltage at the battery is much more than 14VDC, it's probably time for a new converter with smart charging technology.
38,769 PostsLatest Activity: Dec 31, 2014
