crassterExplorer IIFeb 06, 2020Butane vs. PropaneSo I talked to a man that had an coach where the manual states that it can use both Butane AND Propane. Which is better? Worse? Pros? Cons? Why? Thanks!
wolfe10ExplorerFeb 06, 2020butane has more BTU's per gallon, but (actually LARGE BUT) is has a lower boiling point.So, if in cold climates/temperatures, propane is the correct LPG. If higher temperatures, butane is great.Do a little research for boiling point on both and you can determine what is best for your locale.
Related ContentPropane/butane fir RVs in MexicoButane lightersfilling butane cylinderHeating Cost: Electric vs. PropaneBias ply vs. radial tires
