- Son_of_NorwayExplorerIMHO, look for a newer one. Early 90's if you can. Won't be that much more expensive, and several improvements were made to both the coach and the chassis.
- LwiddisExplorer IIIThirty + year old coach...you’ll need to inspect everything.
- MrWizardModeratorfront air bags inside the coil springs
approx $100 for a new pair, and a afternoon of sweating & SWEARING to install them
starters have a tendency to get over heated from the exhaust
and a lot of replacement starters are put in wrong and end up breaking teeth on the 'flex plate ring gear'
replacement starters come with shims for spacing the starter OFF the gear
and a little steel rod to use as the spacing gauge between the starter gear and the ring gear - IAMICHABODExplorer IIIIf this is on a P30 Chassis This Link May interest you.
I had a 86 Winny on a P 30 chassis and it was the most evel thing to drive as I said in a post in that thread.
38,767 PostsLatest Activity: Feb 28, 2026
