Oldme
Mar 29, 2015Explorer
It is possible.
I would not be looking as old as you stated.
The older the unit the more possible work it needs.
If you are a real handy DYI person, you can do most of
what you will likely run into. I see you stated that
"This will be my home for the next several years".
A rebuild with your intended use could be different from
one where you intended to flip for a quick profit. You
would be looking at what you like and not a possible buyer.
Careful inspection of roof, walls, electric and water will
go a long way to cutting expenses. The Class C on the E450
chassis is a real proven work horse. Those on the E350 chassis are
narrower, with less capacity. Tires over 10 years old have timed out
and need to be replaced.
Careful inspection and a lot of work can get you what you want.
38,780 PostsLatest Activity: Aug 05, 2026
