- captron33ExplorerThanks Lou.
- sailor_louExplorerAs cavie identified, the pic shows the valves in the "normal" lineup, which is the water heater inlet open and the bypass secured. If you reposition both valves, the heater should be bypassed. If you still have an issue then it is possible the inlet valve isn't closing.
Lou
05 Travel Supreme Envoy - captron33ExplorerI tried that position and still had fluid running out the hot water tank drain. Do you think the valve failed?
- cavieExplorer
sailor_lou wrote:
I recently posted a pic of the heater isolation and bypass valves on the iRV2 Travel Supreme Owner's Group Forum. You can see it here (Post #28):
Water Heater Valves
Hope this helps.
Lou
Note, that picture is "inuse" not "bypass". - sailor_louExplorerI recently posted a pic of the heater isolation and bypass valves on the iRV2 Travel Supreme Owner's Group Forum. You can see it here (Post #28):
Water Heater Valves
Hope this helps.
Lou
38,782 PostsLatest Activity: Sep 10, 2026
