down home wrote:
The C7 engine is supposed to have a finned aluminum oil pan. Ours did. We discovered two years ago that when the Dealer wrecked it they replaced the pan with a bight orange steel Cat pan and probably explains oil vapor problems maybe no bafeling and designed for a water pump.
Ask Freigthliner or Cat they will tell you this is correct.
we have yet to find out who they had do it. It looks like our dime to correct it 3500.00
NO, it's not supposed to have a finned pan. There's a few zillion C-7s out there with steel pans on them. They CAN come with either one but, there's variable reasons for either. But, by far, about 99.999999% of the motorhomes out there with a C-7, have the steel pan.
Posted By: down home on 09/28/18 02:30pm
and probably explains oil vapor problems maybe no bafeling and designed for a water pump.Ask Freigthliner or Cat they will tell you this is correct.
Whaaaaaaaaaaaaaaat? "No baffling"???? "For a water pump"??????
Well, maybe you've not read the hundreds and hundreds of threads explaining WHY the C-7 CAN produce excessive oil mist from the blow-by tube. And it's NOT from "NO BAFFLING". The oil dip sticks were marked incorrectly and, unsuspecting owners would put too much oil in them, based on the style and type of oil pan. The STEEL pans are designed for a maximum of 19 quarts including the oil in the filter. The aluminum pans were calibrated for 22 quarts, including oil in the filter.
And, may I ask, what in the world does a WATER PUMP have to do with the oil pan? Nothing as far as I know.
With a bit of research, one can find numerous threads on folks that have re-marked their dip sticks, so they reflect the proper amount of oil to be installed after an oil change in their C-7.
Scott
