About 3 years ago I posted a picture of my badly corroded oil pan on my C7 Cat. Well back then I removed as much rust as I could without taking the pan off and coated it with a epoxy product from an a...
Ford gas V8 Engines from about 20 years ago had a problem with oil pan is rusting through as well. The problem on those installed in trucks and vans was that you had to lift the motor out or drop the whole front crossmember in order to change the pan.
