tinkerer wrote:
I have noticed the oil pan on my 2007 coach's C7 Cat has a lot of surface rust on the oil pan with most of the paint peeling off. This is the shallow oil or 19 quart oil pan. I was just wondering if anyone has had the same problem and what they did about it. Maybe I shouldn't worry about it but it does bother me as I don't need a leaky oil pan.:h
tinkerer,
Well Sir, as you can read, you're not alone in this issue. Many of the CAT oil pans, as well as other parts of the CAT engine rust and, some severely. As you can see in the pics I present below, mine was seriously rusted. Very large flaking etc. And yes, I called CAT and, they had one in stock, at just over $400.00 and, they had the gasket and it was around $75.00, if I recall.
I called some sand blasting and powder coating establishments in our area and, by the time it was all said and done, it was going to be very close to the same price. So, I figured what the heck, I'll tackle the job of scraping, sanding, wire brushing, primering and painting. After all, it's my labor and, I'm retired so, who cares.
What you see is about 3 hours work. And, it was done right at, 3 years ago and has not deteriorated to the point at which I started. I used some cheap, "Yellow" paint I had hanging around, along with some left over primer.
Scott
