DaHose
Sep 23, 2014Explorer
If you look in the trim wood section, you might find what you need.
I used aluminum backed, foam insulation from Home Depot. It was the right thickness and insulates well.
Getting the stuff off is a matter of what your rig is made of. Mine was steel, so a grinder with cutting wheel and welding was my solution for the frame structure. The foam and wood was glued with some 3M rubber cement product. The adhesive info. is in my rebuild document.
Jose
Jose
38,778 PostsLatest Activity: Jun 10, 2026
