dcason's avatar
dcason
Explorer II
Jun 22, 2021
Cab/living area COLD weather insulation - comforter?
Okay, we have always used a heavy weight quilt to hang on the cab over bed down to the floor of cab for cold weather camping (which we do a lot of). It isolated the living area from the driving area and gave us a smaller area to heat. I got rid of the one we had thinking it would be easy to replace. Well NOPE....they are all thin or want $130 to replace the twin quilt.
I really liked the quilt because we could flip it up on top of bed when we didn't want to use so no storage issue...it was always attached with sewn pocket/thin board between mattress.
What do you use? I spent about 1.5 hours shopping local and found nothing (I also want a darkER color because we have a dog and don't want to be hitting the laundromat too often). Spent 2+ hours online looking for heavy weight comforter/quilt with no results unless I wanted to spend $120 and still no guarantee it would be heavy just pricey.
So tell me what you use? It worked great by the way to make it a smaller area to heat in COLD weather.
  • Check Lid'l Dolly's factory outlet in Pigeon Forge Tn. They have a web site that may help.
  • Could you somehow sew or attach two thin quilts together?
  • when you stop for the nite make sure the heat/ac is in the off poshion b4 you turn off the motor cover the wind sheald with an inslated cover all that helps us. your quild sounds good to
