Coach-man
Nov 03, 2016Explorer
Several people have asked why, I am not a mind reader but, you should "exercise" the gen set at least once a month! However, to the OP in order to properly exercise your gen set, you should put it under load. You need to determine if you have a transfer switch, or you must plug your power cord into the gen set. Then run it until it gets up to operating temperature for at least 15 minuets. Turn on something that draws enough amps to ensure that the coils dry out, I used to operate the A/C even in winter.
