Sprig
Jan 19, 2015Explorer
gsf35099 wrote:
...Between positive & ground the output is 20.7v.
http://www.iotaengineering.com/pplib/dls30spec.pdf
http://www.iotaengineering.com/pplib/2013_IOTA_Power_Guide.pdf
IOTA does not currently list a 30A 24V converter; so I really don't know what you have.
Unless you have an older different model, the IOTA data sheets show the output terminals labeled as Positive Terminal Lug (Red) and Negative Terminal Lug (Black).
Typically, in an automotive installation, the negative terminal is attached to chassis ground.
If you actually measured ~20VDC at the output terminals, then something is definitely wrong.
Anyways, last reply from me, time to grab the popcorn and watch how this plays out.
ON EDIT: So long as the above posts don't change, anyone notice what does not quite add up?
38,763 PostsLatest Activity: Dec 05, 2025
