Effy
Oct 30, 2014Explorer II
Anything "can" be done but easily? No. You would have to find a suitable space somewhere else that could accommodate it, you can't just put it in another bin as it requires open space, you'd likely have to build some framework to support it, re-route or fabricate the exhaust, heat insulate it, make sure it can breathe, re-run the wires - likely having to buy a lot of wire, re run the fuel line etc etc. So yes it can be, but it's not as simple unbolting it and moving it. Usually they put them where it makes the most sense in relation to everything else. You'd almost be better off removing it, selling it and getting a portable gen you can place on the ground. Of course then you wouldn't have power travelling.
38,766 PostsLatest Activity: Jan 10, 2026
