holstein13
Apr 27, 2014Explorer II
Mr.Mark wrote:
We have that on our current coach and have the matching drive and tag wheels.
I think Prevost just does it that way as other chassis manufacturers (Freightliner may have done the same). I remember when the Allegro Bus by Tiffin went to the Spartan chassis and that's when I noticed the matching wheels. Monaco also did the same on the Roadmaster chassis having matching wheels.
MM.
Mr. Mark, you keep referring to "matching" wheels. I guess you mean that both wheels match the same orientation, right? I believe the wheels are exactly the same it's just that they reversed the orientation of the tag axle to put the hub on the outside.
In fact, I think you could switch the tag wheel and the drive wheel by simply taking them off and mounting one in place of the other. They are interchangeable, right?
38,782 PostsLatest Activity: Sep 10, 2026
